New From Electroputere Craiova
Re: New From Electroputere Craiova
Postby vlada » 04. 10. 2010. 1:55 GMT +0000
Postby Electrica821 » 04. 10. 2010. 10:32 GMT +0000
The New Transmontana it's Redy .More picture Tomorow when i will meet her on the Railway Expo in Bucharest
Electrica821
Postby mladen86 » 04. 10. 2010. 16:39 GMT +0000
Can I get some technikal data from transmontana? :oops:
mladen86
Postby zlatan » 04. 10. 2010. 19:24 GMT +0000
zlatan
Postby mladen86 » 04. 10. 2010. 19:43 GMT +0000
a ne razumem da zasto je ona samo preradjena lokomotiva posto je phoenix bila sasvim nova loksa!
mladen86
Postby zlatan » 04. 10. 2010. 20:20 GMT +0000
zlatan
Postby IIIALEKSANDARIII » 04. 10. 2010. 20:53 GMT +0000
Sto nema retrovizora,da vidim tog MV koji ce u nocnim uslovima da na TFT-u vidi dalje od 4-og vagona.
Postby Electrica821 » 05. 10. 2010. 2:09 GMT +0000
i will get you tehnical data today . right nou i am on the train going to te railway sumit in bucharest where they will prisent Transmontana and Other Softronic Locomotive . nether Softronic LOcomotives are Le5100kw all softronic Locomotives are 6000kw or 6600kw
Electrica821
Postby Electrica821 » 05. 10. 2010. 19:27 GMT +0000
So the New Softronic TransMontana Have's 8300kw :shock: :shock: The Inginer Whi Build It told Me :D itss al made by Softronic Craiova and She Will be run test;s in Hungary and Germany
Electrica821
Postby Boris712 » 05. 10. 2010. 19:45 GMT +0000
It's unlikely that transmontana has 8300 kW, if you mean the continious output. Maybe the maximum 30 or 60 minute output stands at 8300 kW and continious at 6600 or so.
Can you check last information again? Try to specify what kind of output is it.
Postby mladen86 » 05. 10. 2010. 21:15 GMT +0000
when will it come here to hungary?
mladen86
Postby zlatan » 05. 10. 2010. 22:22 GMT +0000
zlatan
Postby Electrica821 » 06. 10. 2010. 10:15 GMT +0000
all part's are Moddified the loco fast sppeed is not 120 for Fright hase modification to go no more of 12 normaly it's go up to 200 km/h
Electrica821
Postby zlatan » 06. 10. 2010. 23:44 GMT +0000
8100kw-law of a primary 10 min maximum current strength of the main transformer. When the locomotive LE5100 (5100kw nominal tractive force) is the largest power autotransformer secondary windings traction is 5790 kVA. There is a possibility that the forces of traction with coil modification and higher, but still good to know that Phoenix has a locomotive beneficial effect of these 5100kw imposed on engines. As for locomotives Transmontana, it is a completely new method of transformer winding circuit to a higher transmission power, so the problem is not built strong asynhron traction motors, depending on the secondary windings of the same transformer. It is evident that the locomotive Transmontana yet contemporary solution of locomotive Phoenix. Thanx dor new information, Electrica, I welcome you my friend :I
zlatan
Postby mikiza » 07. 10. 2010. 10:20 GMT +0000
Does this new machine have new bogies, something like EMD radial bogies? To reduce wear of tracks, and improve performance. If not, all those improvements are lacking one big leap forward, because, as I understood it, the greatest problem with older romanian CoCoCo locomotives is exactly that high impact on tracks and resulting deterioration of both tracks and wheels.
mikiza
Postby Electrica821 » 07. 10. 2010. 14:41 GMT +0000
Yes Transmontana have new bogy's tehnology but look the same at the old the Suspension has bee modified whit Elastic system ...
the Control system it's Siemens and Softronic Creation
When the Softronic Enginer TOld Me it's 8300 kw i was shook and he show'd me the Locomotive Board book and show'd to me that the New Softronic Transmontana has 8300kw
Electrica821
Postby mladen86 » 07. 10. 2010. 15:32 GMT +0000
And when can I see this loco on hungaryan tracks?:P:D
mladen86
Postby Electrica821 » 07. 10. 2010. 21:35 GMT +0000
soon becouse it;s must be omologate for Hungarian railways...
Electrica821
Postby zlatan » 03. 11. 2010. 0:59 GMT +0000
zlatan
Postby zlatan » 23. 12. 2010. 23:43 GMT +0000
zlatan
