New From Electroputere Craiova
Re: New From Electroputere Craiova
Postby Electrica821 » 20. 09. 2010. 6:14 GMT +0000
It dosn't matter the Shape how much matters how it work No contry Will buy a Expnesive LOcomotive when you can buy a must chipper locomotive and good , In romania the BR 189 Locomotive DOsnt do The Job on Prahova Valley you need 2 BR189 at a Fright Train . So that's not good anyway the Company CTV stop Pulling train's on prahova valley whit BR189 and start going whit the old LE5100 Co'Co' Sistem . So :) it dossnt matter Modern but Dosnt Do the job :) So are money trow'd on the window.
So The BR189 is not such a good locomotive on Hiils and Ramp's
Electrica821
Postby jz441 » 20. 09. 2010. 14:47 GMT +0000
Electrica821 wrote:In romania the BR 189 Locomotive DOsnt do The Job on Prahova Valley you need 2 BR189 at a Fright Train . So that's not good anyway the Company CTV stop Pulling train's on prahova valley whit BR189 and start going whit the old LE5100 Co'Co' Sistem . So :) it dossnt matter Modern but Dosnt Do the job :)
BR 189 doesn't have the weight to get the required traction out of Bo'Bo' system.
Postby Electrica821 » 20. 09. 2010. 16:23 GMT +0000
I know that it was Bad Example that the SImens locomotive's are not good int this area . a nother bad Example is the Taurus Locomotivie . Obb made in romania> Rail Cargo Romania obb give Romania 4 Taurus Locomotives for Fright Traction to Bring in to Europe Dacia Cars and Petrol and other Goods . But after 3 month didn't worck whit the taurus and Railcargo Decide to Rent Le5100 Kw . :)
Electrica821
Postby Mali Panta » 20. 09. 2010. 18:48 GMT +0000
That locos will be good for as when we had speed railways with small curves. It will just cover each other.
Postby Electrica821 » 20. 09. 2010. 18:54 GMT +0000
Yes :D
Electrica821
Postby 461-001 » 20. 09. 2010. 21:50 GMT +0000
TransMontana seems like good locomotive , it will be great to serbian railways buy them :)
461 ZAKON
Postby darko06 » 21. 09. 2010. 11:08 GMT +0000
EMD je moja strast!
darko06
Postby Electrica821 » 21. 09. 2010. 12:38 GMT +0000
On Prahova Valley its more then 34 real declivity :) going up on 1000 Meters in Predeal Station ...
Prahova Valley
Going Up on Prahiva valley 2 Le5100Kw whit ICOL ( Instalation for Control and Traction for Locomotive) 15 waggons
Electrica821
Postby Electrica821 » 21. 09. 2010. 13:38 GMT +0000
Testing a Le5100
Electrica821
Postby Vantage » 21. 09. 2010. 21:19 GMT +0000
This is how taurus accelerates :mrgreen: :mrgreen: :mrgreen:
Vantage
Postby Electrica821 » 25. 09. 2010. 17:40 GMT +0000
First Accident Whit a Phoenix Locomotive :) 91-53-0-478-001-7 The FIrst Locomotive From Softronic Craiova Crash in a Nother Engine
reson ? The Hungarian Locomotive Driver Pass't a Signal who was on the STOP light and Hit a nother Fright Train from Grup Feroviar Roman => GFR or in Europe know like Rolling Stock
This Locomotive Used to BE
Source : http://www.blackrail.ro => reporter Krupp
Electrica821
Postby Electrica821 » 26. 09. 2010. 20:39 GMT +0000
Then .... the magic Happend after the Accident 001 have been transferd in to DB railways
YES . Germany Bought the LE6600 kw Who sad that the LE6600 is not Good
Take a Look at this . THE first Romanian Electric Locomotive at DB
[url]
http://img689.imageshack.us/img689/7801/spa0183b.jpg[/url]
Electrica821
Postby Boris712 » 26. 09. 2010. 21:14 GMT +0000
Maybe DB only hired it for testing?
Postby Electrica821 » 26. 09. 2010. 21:56 GMT +0000
It's not For testing it's for tranzit :d Softronic Craiova Made that locomotive Bi-sistem for entering in Germany , Germany need'd a powerfull locomotive Co'Co for tranzit and easy to take care off from Romania-Hungary-Austria-Germany
Electrica821
Postby Boris712 » 26. 09. 2010. 22:02 GMT +0000
So if I understand well she can also drive on 15 kV 16 2/3 Hz?
Postby Electrica821 » 27. 09. 2010. 7:15 GMT +0000
Yes :D
Electrica821
Postby mladen86 » 28. 09. 2010. 15:32 GMT +0000
is there some other photos from it?
Its interesting the country code is 53 :s
mladen86
Postby Electrica821 » 29. 09. 2010. 10:45 GMT +0000
i will try :)
Electrica821
Postby zlatan » 02. 10. 2010. 18:37 GMT +0000
zlatan
Postby Electrica821 » 03. 10. 2010. 10:18 GMT +0000
Electrica821
